Kdx drunk Water
kdxquebec
Kdx drunk Water
Post by kdxquebec »
Hi! I felt in a river with open throttle :roll:
Glou glou! My cylinder was full of water! We revoved the plug and removed the water with the bike up side down. (in the air boot and airbox too) A lot of water was in the cylinder.
After the bike started within 20 kick. I was 2 hours from home. The bike was ok and I did not see differences..
I cleaned the carb/air filter and airbox/aibox boot/replaced tranny oil/replaced plug when I got home.
What should i do now? sell the bike? repack the silenser and split the crankcase??lol :mrgreen: :shock: :shock: :shock: ???? :shock: :shock: :shock: :shock: :shock:
thanks a lot philippe
Change the oil a LOT over the next SMALL amount of time. Several times anyway.
You're likely OK. Especially if the water was 1/2-way clear. Especially if the 2-hour ride back was OK.
Repacking wouldn't be a bad idea..but it will dry out eventually!
Hey! Don't do that!! :wink:
...where's the pics!!??
kdxquebec
Post by kdxquebec »
Should I replace my username for MR.PICTURES! :mrgreen:
Thanks C.C.
Uh....it's ankle deep.... :roll:
Seriously, how did you get THAT shot? Someone was just waiting for you to fall over?
See anyone you know at the bottom of your screen? ;)
fuzzy
Post by fuzzy »
ATF will go into solution with water, and allow you to drain it out. Then change back to oil...
kdxquebec
Post by kdxquebec »
na..this is just a picture of me falling in a last summer ride.
The one I went down last weekend was a lot deeper,I mean between the ankle and the knee.
quote (C.C) ***Seriously, how did you get THAT shot? Someone was just waiting for you to fall over? ***
I have a lot of fans who are waiting for me in the woods :mrgreen:
thanks fuzzy
cfspawn
Post by cfspawn »
HaHA your a legend Phillippe
i have done that many a times before my top end rebuild and found no problems
i just make sure i drain the oil. and do the filter etc you know the drill
IdahoCharley
Post by IdahoCharley »
You should be good.
If we have a bike 'disappear under water' for even a second or two I like to also drain the gas tank and check to be sure no water entered it which will damage the bike when I go on "reserve". I also pull the ignition cover and spray down with WD-40 to help prevent any corrosion.
Sound like everything else you got covered. :mrgreen:
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
beeds3000
Post by beeds3000 »
How do you pull the ignition cover to spray it with WD-40 I think mine is sealed ???
Geoff T. Biderman
Colorado Mike
Post by Colorado Mike »
It's the left side case cover.
IdahoCharley
Colorado Mike is correct - left side case cover - stator, exiciter and lighting coil area.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
Sealed? Well...yeah...with a gasket and maybe some sealer.
Sealed? Not a one-piece-can't-get-there thing.
