Water Pump seal Replacement..
Postby cfspawn » 10:45 pm Jul 06 2006
Hey all
I have just received my new seals for my water pump there is 2 seals one is larger than the other i would imagine one would be for the water seal and the larger would be for gb oil can i get and replace both of these without taking the whole side cover off?
cfspawn
Has thanked: 0 time
Been thanked: 0 time
Postby m0rie » 12:08 am Jul 07 2006
No you have to remove the clutch cover, water pump cover and side cover to remove the water pump shaft. Check the shaft when you pull it apart. If it is grooved your going to need to replace it as well or the seals will fail again in short order.
m0rie
Has thanked: 0 time
Postby cfspawn » 02:07 am Jul 07 2006
what about for just the water seal? or is it best to do em both.
cfspawn
Has thanked: 0 time
Postby m0rie » 09:33 am Jul 07 2006
Its best to do them both as well as the bearing. On my 89 the shaft was grooved, the seal was toast and the bearing wasn't in the best of shape. Since it takes some effort to tear it down to check it's worth just replacing the whole mess if the parts are border line so that you don't have to tear it back down again in 3-4 months.
m0rie
Has thanked: 0 time
Postby cfspawn » 10:51 am Jul 07 2006
Morie i need your help.
I have disassembled the whole water pump system including impeller, bearing and seals but the seals i ordered for this model (90 KDX) dont even look close to fitting and thus cannot figure out where they go!
I have noticed that my waterpump setup is the same as a H model KDX (95 ownwards) for instance my impeller is a round (turbine shape) unlike what i am suppose to have (according to buykawakaki part diagrams and also my service manual states that it should be a "ninja star" shaped impeller as well as a bolt to hold it on mine uses a nut. the two oil seals that i received (kay dee exers picture 4) are totally different from the ones that were in the bike already(between the side case and the bearing would be at least doubt 30-35 mm,
the seal on the far right of this pic is the old worn oil seal where the seal on the far left is supposed to be the replacement (obviously a big difference)
there will be more pics to follow which kay dee exer has uploaded for me.
cfspawn
Has thanked: 0 time
Postby cfspawn » 10:53 am Jul 07 2006
sorry try again
cfspawn
Has thanked: 0 time
Postby KDXer » 11:06 am Jul 07 2006
KDXer
Has thanked: 0 time
Postby m0rie » 11:11 am Jul 07 2006
Well i'm completely lost now cf. From what I recall that looks nothing like the waterpump setup on my 89. I wonder if this is another on of those over the pond differences. Let me see if I can dig up the fiche diagrams for the SR models and see if the water pump is different from my E series.
m0rie
Has thanked: 0 time
Postby cfspawn » 11:20 am Jul 07 2006
Thanks man your a champ! Yes it is a hairy one
cfspawn
Has thanked: 0 time
Postby cfspawn » 11:27 am Jul 07 2006
Do you recall morie if your water pump shaft gear was (pictured last above) was or is a nylon gear or steel? as my manual states that it should be a nylon but its steel!
cfspawn
Has thanked: 0 time
Postby m0rie » 11:46 am Jul 07 2006
I believe it was steel, but its been quite a while since I replaced it.
m0rie
Has thanked: 0 time
Postby kdxquebec » 12:19 pm Jul 07 2006
eh???????
do you own a kdx? :shock:
My 89 model waterpump look a lot different too!
kdxquebec
Has thanked: 0 time
Postby cfspawn » 12:36 pm Jul 07 2006
Yes i must have the wrong oil seal for behind the shaft bearing.. there is no way i can tell that a bearing that small can be streched or pressed to that size
cfspawn
Has thanked: 0 time
Postby KDXer » 12:29 pm Jul 08 2006
Does this water pump setup look familiar to anyone ?? Can any H model users shed some light on this ?? I haven't had my water pump apart so I can't verify if it is indeed the same as a H models setup (although the buykawa part diagrams seem to indicate it is). Any help would be greatly appreciated as we are both pulling our hair out trying to decode the discrepancies. :? :? :sad: :sad:
KDXer
Has thanked: 0 time
Postby KDXer » 01:33 pm Jul 08 2006
I finally figured it out (AFTER BASICALLY LEARNING JAPANESE). A huge thanks to everyone that helped. FTR JAP 90 KDX200 and 90 KDX200SR have a different water pump setup.
90 KDX200
90 KDX200SR
KDXer
Has thanked: 0 time
Postby m0rie » 01:50 pm Jul 08 2006
Thats the ticket Trev! I couldn't find the Japanese SR diagrams but its pretty obvious that they are different from that fiche diagram.
m0rie
Has thanked: 0 time
Postby KDXer » 02:06 pm Jul 08 2006
The thing that threw us (me) off is Spawns bike has a 35MM carb where as the SR is pictured with a round slide carb of some description. His carb is the same as a non SR model (E model with cresent shaped slide). FTR Heres the website I found the info.
http://www.kawasaki-motors.com/parts_cat
KDXer
Has thanked: 0 time
Postby cfspawn » 09:35 pm Jul 08 2006
Trev your a legend. Yes that is the go. although still doesnt make alot of sense to me as my Frame number is DX200E-010878 but yet to confirm the engine number and my carb is a 35mm carb and has no wiring for any blinkers or anything.. Werid. but ill go with that I have sent the old seals back for credit and they have the correct seals in stock so thats a bonus hopefully ready for this coming weekend :supz:
cfspawn
Has thanked: 0 time
Postby canyncarvr » 11:09 pm Jul 08 2006
m0rie wrote:I wonder if this is another on of those over the pond differences.
M0rie said this before I got here, so I didn't figure repeating it would be of any use.
I'd looked for the SR model at buykawi..they didn't list it.
KayD wrote:A huge thanks to everyone that helped.
I'll read that as written. Thanks m0rie!
:wink:
**edit**
It took awhile to load...but thanks for that link KayD!! :roll:
Images: 26
Has thanked: 0 time
Been thanked: 2 times
Postby KDXer » 11:30 pm Jul 08 2006
canyncarvr wrote:M0rie said this before I got here, so I didn't figure repeating it would be of any use.
Indeed he did, unfortunately we were thrown off by his having a 35mm carb and lack of oil injection etc.
An EXTRA special THANKS to Maurice and and also credit to Philippe. Cheers guys.
canyncarvr wrote:It took awhile to load...but thanks for that link KayD!! :roll:
My pleasure... Have fun working it all out. :wink:
KDXer
Has thanked: 0 time
Return to KDX General Q&A
Who is online
Users browsing this forum: Bing [Bot], Google [Bot], Nickodemo and 7 guests
