Flat down low, flat mid, but Rocket at high revs?
Posted: 01:56 pm Mar 29 2023
Yes you heard that right. After a full engine rebuild on my 2004 KDX200 the power delivery is way off. Power Is very flat at low and mid rpms, even mid high rpms. But if you really let it scream, the power suddenly goes up 300%. Why do you think it's doing this? What are the most likely 5-10 issues to check first in your opinion?
Here is a list of things that changed since it last ran well:
All seals have been replaced
New crank and main bearings
New piston and rings
New Boysen Power Reeds
Stator plate moved about a millimeter CCW (an effort to gain top end power)
Clean air filter
Gas used was 4 month old premixed filled to top in plastic container...its all I had at the time!
Let me know thoughts, thanks!
Clean air filter
