FMF Fitting Probs
cfspawn
FMF Fitting Probs
Post by cfspawn »
Hey all just put me new Fatty pipe and silencer on. an awsome upgrade and given me at least 40% more power (as my stock was bent)
Only problem is that one of the holes dont match up the three other mounts line up perfect except this one. here is a pic
http://cfspawn.gallery.netspace.net.au/ ... e_Pics_011
doesnt seem to be worrying it as its well and truley bolted on there just curious if anyone else have had this..
cfspawn
Post by cfspawn »
the mount is just before the start of the expansion chamber.
How'd that get there? FMF's pipe builders are smoking weed again! :rolleyes:
m0rie
Post by m0rie »
cfspawn - Are you using the rubber mount dampers to mount the pipe? There should be one that mounts from that mount point on the pipe to the frame.
cfspawn
Post by cfspawn »
only on the silencer morie... doesnt look like i got any for the pipe itself it dont line up anyway that was my main concern
It's all coming back now... yes there is suposed to be one there... my rubber was torn and it was basically decoration on my 92.
You didn't have them on your old pipe? You are supposed to reuse them for your new pipe...
m0rie
Post by m0rie »
You'll need to pick up 3 of them to mount the pipe correctly. Give me a sec and i'll scare up a part number for you.
m0rie
Post by m0rie »
Looks like the part number is: 92075-1891 DAMPER,MUFFLER 3x
All the mount tabs on the pipe are offset so that they line up with the damper mounts.
cfspawn
Post by cfspawn »
PIPE or Silcencer ? i have resued the old ones for my silcencer dampers but nothing for the pipe weird..
cfspawn
Post by cfspawn »
I got 2 Metal round spacers which i have used for the silcencer so it lines up properly and bolts on straight hope these arnt it.
cfspawn
Post by cfspawn »
I got it now.. after looking at the parts fisch i found that i am missing these rubber dampers (all three) so i have ordered now should be here by the end of the week
Thanks guys.. :prayer:
