12 tooth in front what goes good for rear with it ???
beeds3000
Post by beeds3000 »
I bought a 12 tooth sprocket for the front to give me a little more torque I'm in need of replaceing the rear should I just get the stock 47 tooth or is their a better number that would go with that 12 tooth up front ??? what do most people run if they have a 12 tooth ???
Geoff T. Biderman
bradf
Post by bradf »
I run a 12 CS and stock rear. It has cut down the top end speed but I rarely see 4th gear let alone the others past 4th.
clutchcover
Post by clutchcover »
Stock works great, it'll still run 60-65mph even with the 12t.
97 Kdx200
Summuda goodies.... But not quite enough.
Green Hornet
Post by Green Hornet »
Get a RB Carb & Head Mod, VF3, pipes and go from there. I can pull a gear higher with those mods and I run stock front & rear sprockets.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
quailchaser
Post by quailchaser »
Depends on what terrain you ride, your riding style, rear tire size, ect....
You say you want more torque...more than what? What gearing are you currently running?
Going down 1 tooth in the front is approx. the same as going 3 teeth bigger in the rear. CLICK HERE for Inda's post to the Chart. 12/47 is closest to 13/50.
Later
Robb
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
crazyaboutriding
Post by crazyaboutriding »
well, like the previous person had stated, 12:47 is close to 13:50. you probably would have been better off to go with the 13:50 because using the smaller sprocket in front would put more torque on the driveshaft, and may cause the engine to wear out easyer. it also makes it just harder for the engine to spin it (not having as many teeth to grab) and could cause you to loose a small ammount of power.
kevin
Kevin
'00 KDX 200
bradf
Post by bradf »
A 12 CS is a simple gearing change from stock. It is cheaper and easier than replacing a rear sprocket to achieve the same gearing ratio. In my case this ratio allows me to stay in 3rd gear longer and with the SSS 3rd gear is a very good gear to be in. With the stock 13 CS gearing I had to drop out of 3rd too much. The one less tooth is not going to make the engine wear out easyer or easier. The 12 tooth CS gives it plenty of teeth to grab. Improperly maintained chain slack will create problems and wear in any case, but not a 12 CS. "Makes it harder for the engine to spin it"... "Loosing a small amount of power"? Just the opposite. It makes the power transfer easier. Detroit has wrestled this same issue for years. Install 4.11's and get the torque to the wheels but sacrifice overall mileage or install 2.73's and get better mileage to satisfy the EPA but less torque to the wheels. To answer the original question...I already did.
Green Hornet
I agree with BradF-A 12 tooth is not something I would worry about.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
layoutd
Post by layoutd »
while waiting on my 13t front, i ran a 12/50 gearing. it was actually very fun. especially on the gnarly rocky stuff. i rarely ride stuff that allows me to get past 4th as well.
Eatin' ain't Cheatin'
