ok go easy on me i'm changeing the piston on my 03 220 with a wiseco piston having trouble getting jug over pistonwhat am i doing wrong i dont want to damage anything .. thanks for your help
tom
You could also try the technique of installing the piston into the jug while it's on the bench. Then lower that assembly over the rod and insert the wrist pin. Have one circlip already installed in the piston too.
The piston should be 69 mm for a standard bore cyl. . The piston won't fit if you don't line up the rings on the pins. Also make sure it's facing the right direction, and follow the manual's recommendation on clip alignment.
