I used to ride an 03 yz250, but haven't ridden in some years. I always loved my brothers 220 and picked up a '98 with '04kx 250 forks and some nice upgrades. It runs great and makes all the right sounds but I have been researching the kips and decided to pull the slotted cover and it functions as itshoukd when revved but but if I turn it by hand it rotates about 90 degrees or so both ways smoothly but does not spring back on its own. Should that be a reason for concern? Any other advice Thanks?
Thanks, Theo
Tips for new owner
Re: Tips for new owner
Hmm, it's been a while since I've worked on the top end on my KDX so hopefully someone will correct me if I'm wrong but... IIRC, you really shouldn't be able to operate the KIPS by hand as the spring that regulates it is fairly stiff.
Trying to turn the KIPS actuator by hand can lead to breaking off the pin at the governor. Usually it happens when folks don't realize its left hand threaded at the top, but also when turning it by hand (or wrench).
Thanks, I'll not mess with that. But after riding a bit it moves more freely and returns
