Advanced Timing Question
cfspawn
Post by cfspawn »
Hey all..
Had something pop into me head before and wondered what everyone thought.
when I replaced my exciter coil on my stator i noticed my timing was advanced by one notch (there are 3 lines) so i reset it back to factory which is the middle line or notch as said in the manual. When i rode the bike it felt a little restricted but had heaps more bottom end. so i put it back to the advanced setting as it gives me more top end. Is this the right thing to do or should i leave it at the factory setting, and does it hurt anything mech wise running advanced? your thoughts would be great as i am thinkin of putting it back to standard.
Thanks guys. :twisted:
m0rie
Post by m0rie »
If I had to guess I'd say thats the difference between the 89 and 90-94 E KDX's. The 89 had its timing slightly retarded vs. the 90-94 KDX's which was advanced for more top end HP.
Green Hornet
Post by Green Hornet »
It really comes down to your preference. If your riding for the day is going to consist of needing lots of lowend, than Retard-needing lots Rev than- Advanced.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
IdahoCharley
Post by IdahoCharley »
Yep the adjustment is put there for you to use (tailor your bike's performance to a degree). If I recall correctly - it is even spelled out in the service manual.
IMO - Too much of anything is not likely always good mech. wise - I view this ignition advance/retard as an indication by the design engineers on what they believed was acceptable range of ignition timing based upon some preset parameters. I've played with the ignition timing a little bit and I think that if your running a rev pipe and want a little more low end grunt there is some to be had. If I recall correctly we changed the main jet one size and got back most of the over-rev after retarding the ignition.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
cfspawn
Post by cfspawn »
YEah thats awsome. I realise its personal preference but not to sure what setting would be best for the woods probably bottom end to get out of the thick stuff.
re: the advanced setting as it gives me more top end
That is incorrect.
re: got back most of the over-rev after retarding the ignition.
That is correct.
As long as you're going to be moving things around...maybe start with knowing what said movement is going to effect/accomplish.
BTW...looking at it, the KDX FW rotates CCW. To advance the timing you move the stator clockwise...and versa vicey.
fuzzy
Post by fuzzy »
^ CC is right....These aren't 4strokes! :mrgreen: Timing is basically opposite in theory. A small adjustment is all that's needed also. Well unless you're timing for methanol or something...
Rhodester
Post by Rhodester »
I advanced mine a little past the most advanced mark to enhance bottom end.
'95 200H
