top end question
Posted: 11:32 am May 03 2006
by rollerman
hey guys ,i just took apart my top end my piston is in good shape except for carbon on top (cuold be from riding with 9 yr old) the kips valve is pretty clean and working properly should i still take themapart? and yes i'm sending my carb and head out to ron... i'm running a gnarly woods with the turbine2 Q silencer power reeds .with head mod and carb done will that change the bike a lot i ride tight trails in new hampshire... it only took me 1.5 hrs to tear down...
thank you
tom
Posted: 11:49 am May 03 2006
by Green Hornet
Yes it will change the bike. You will have a wider/more usable power spread. Try a rev pipe on the 220 along with VF3.
Posted: 01:19 pm May 03 2006
by bradf
This is the time to replace the stock piston on that 220. (assuming it is stock)
Posted: 02:08 pm May 03 2006
by rollerman
already ordered a wiseco piston
Posted: 06:28 pm May 03 2006
by Mac
Where do you ride in NH?
Posted: 06:55 pm May 03 2006
by rollerman
rockingham trail clough state park claremont there are a lot legalriding areas in nh
Posted: 11:18 am May 04 2006
by canyncarvr
re: pretty clean and working properly should i still take themapart?
I wouldn't bother with it. Guess that would depend on what 'pretty clean' means.
If you can activate the KIPS via the nut under the LH cover easily, and the KIPS returns to its stasis point when you let loose of the nut (return pressure comes from the spring assy in the case. If the cylinder is off, it won't HAVE any spring pressure on it) it's fine.
Posted: 06:39 pm May 04 2006
by rollerman
yes it rotates easy two shafts are spinning freely one wipe and they were clean
Posted: 10:37 am May 05 2006
by canyncarvr
Sounds all good.
Unless you're interested in taking the thing apart just to see how it works..why bother?
Let us know how you like it when you're done!
Posted: 06:45 pm May 05 2006
by rollerman
yes i will i have to find time to ship my head and carb out working 13 hr days ..
