top end question
- rollerman
top end question
hey guys ,i just took apart my top end my piston is in good shape except for carbon on top (cuold be from riding with 9 yr old) the kips valve is pretty clean and working properly should i still take themapart? and yes i'm sending my carb and head out to ron... i'm running a gnarly woods with the turbine2 Q silencer power reeds .with head mod and carb done will that change the bike a lot i ride tight trails in new hampshire... it only took me 1.5 hrs to tear down...
thank you
tom
thank you
tom
03 kdx 220 mine
05 pw 80 son
05 pw 80 son
Yes it will change the bike. You will have a wider/more usable power spread. Try a rev pipe on the 220 along with VF3.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
re: pretty clean and working properly should i still take themapart?
I wouldn't bother with it. Guess that would depend on what 'pretty clean' means.
If you can activate the KIPS via the nut under the LH cover easily, and the KIPS returns to its stasis point when you let loose of the nut (return pressure comes from the spring assy in the case. If the cylinder is off, it won't HAVE any spring pressure on it) it's fine.
Sounds all good.
Unless you're interested in taking the thing apart just to see how it works..why bother?
Let us know how you like it when you're done!
