Massive Amount of Shavings
I have this 2004 kdx 220 and i was on this forum before due to the kips actuator pin shearing off. I cleaned the side of the engine with some diesel and i could not see any more debris. i was able to spray some onto the other side of the case and no shavings were drained out. I also changed the clutch basket and disks due to the old one having excessive wear, and it has no markings or scraps after riding it for a few hours. I drained the oil and there seems to be lots of metal shavings found in it, i dont understand where the shavings are coming from.
Re: Massive Amount of Shavings
Sorry, but it is time to split the crankcase halves and fully inspect the inside parts.
Sounds like it. I was pretty intimidated when I had to rebuild mine, but it turned out not to be so hard after all. Bag and label parts as you take it apart so you don’t end up with stuff left over!
If you flushed it out thoroughly and are still getting debris then its time to open it up.
I have found that if I don’t lean the bike all the way to the ground on the left side, I don’t get all the oil out.
