Posted: 06:31 am Jan 08 2005
The KDX clamps are out of the question. In order to make use of them I would have to machine the inner diameter of the fork area to a point that would make them very unsafe. Therefore I "think" the easiest way to get around the actual mounting issue is going to be machining the Suzook stem to fit the inner diameter of the I [/b]do have the the Suzook triple clamp assembly with stem and bearings. I also have the axle.
The forks came from a 98' RM 250 I'm pretty sure they are 49mm units. I chose them because I wanted to stay with conventional forks. I think they would be best for the terrain I usually ride. Plus they don't have nearly as many problems with fork seal leaking.
________
Hotbox Vaporizers
________
Hotbox Vaporizers
