Pro Circuit 296 clearance
TEEEE
Post by TEEEE »
Help! I'm installing a PC Platinum 2 pipe and a PC 296 SA on my 2002 KDX 200. The pipe matches up fine but the spark arrestor is crazy long and hits the rear fender (stock) so badly that it won't bolt up. I've heard of others using spacers for clearance, but then it will ride well outside the fender. Have any others had this problem? Should I just shave out the rear fender?
Thanks,
-T
Colorado Mike
Post by Colorado Mike »
I don't have one, but I've always heard that PC stuff fits better than FMF. Maybe you got the wrong silencer? Is there a number stamped in it ? I'd call PC and get them to confirm that it's the right one and/or send you a new one.
As much as this stuff costs, it should bolt right up.
TEEEE
Post by TEEEE »
That's kinda what I thought. All the packagaing says it is the right one and the mounting holes line up, it is just long so it hits the fender at the end. And the sticker is on the inside of the spark arrestor, which is a little odd.
-T
Colorado Mike
wondering if it was mis-packaged. A KX85/100 has the silencer on the left side. maybe you got one of those. My kid needs one, so if that's what it is, and they tell you to keep it, I'll buy it off you .. :lol:
motorhed220
Post by motorhed220 »
Let me know how this PC pipe and silencer works for ya...im buying a piep soon, and want to know if PC or FMF is better...
:partyman:
Live to Ride, Ride to live!!!
Green Hornet
Post by Green Hornet »
Just a thought, is your Sub-Frame twisted a bit from a crash, thus causing the pipe to hit the plastic??
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
TEEEE
Post by TEEEE »
:grin: Yeah, I thought of that. It HAS been crashed...but I don't think it could have twisted enough to be this far out of alignment. I'm going to call Pro Circuit tomorrow...maybe it is the wrong part, but I kinda doubt it since the mounting holes line up like they should.
TEEEE
Post by TEEEE »
I called PC and they say I’ve got the right part and that it should not hit the fender. They didn’t know what to say other than maybe the subframe is probably bent. I think that’s the case after all. So I could:
1. grind the fender
2. return this 296 for something shorter
3. put the stocker back on
Based on the input I’ve seen here, I might just stick with option 1...
Green Hornet
Can you use Rubber Bushings/Washers and a Longer Bolt to give more clearance from the fender??
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Colorado Mike
option 4) fix your subframe :lol:
Green Hornet
Ask Ski-If anyone can fix one he can :rolleyes:
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
TEEEE
Post by TEEEE »
Bolts up just fine, not sure what the problem was before. :lol:
It ain't pretty, but it's effective. Shhh...don't tell anyone but I had to grind a little steel off the ol' frame to fit it. That sucker is bent. I knew there was a reason I bought a used bike....
IdahoCharley
Post by IdahoCharley »
With as close as the pipe/silencer fit a couple of millimeter of twist or bend in a subframe area make a big difference. Glad you got something worked out.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
crazyaboutriding
Post by crazyaboutriding »
Motorhead220- I'm not sure how the PC pipes work, but i have a FMF and it sure runs great.
Kevin
'00 KDX 200
