how do you dissasemble the throttle valve to adjust needle.
the trail rider
Post by the trail rider »
I cant figure it out what do I do.
6mm cap on top... remove it and turn the slide upside down and it will fall in your hand. Use a 6 sided socket.
the trail rider
hey thanks. I just put my vforce 3 and my pipe on and rejetted to what I think is right. stock carb 148 main 40 pilot and 2 turns out on the air screw. I left the needle like it was cause I didn't know how to adjust it and it seems okay. but I will adjust it after a couple of rides. boy taking the carb off is a pain in the A$$ all those hoses to disconnect. thanks the trail rider
get a lift, fat chicks can't jump!
when in doubt gas it!
Colorado Mike
Post by Colorado Mike »
Let's see.. there's the fuel hose...and that's it. You don't need to take the overflow tubes off if that's what you're talking about.
the trail rider
oops and it was a pain to get them on to. duh me.
