Kips exhaust rod o ring
- Country: thailand
Does anybody know more about replacing the o ring on the right hand side exhaust valve rod. Nothing listed on the parts diagram . This seems to be a flat o ring and is not supplied in any top end kit. When I did a leak down test it was leaking very badly from the right hand side power valve cover. Am I right in assuming this o ring helps seal in tandem with the right hand side shaft seal. Google search turns up nothing.
Re: Kips exhaust rod o ring
Do you have a link to an SR parts diagram? Thanks.
- Country: thailand
I don't have a link. Except for oil injection and electrics I'm not sure much else is different. Will the parts diagram have a part number for the o ring I am talking about ?
- Country: thailand
After I dummy assembled it it's easy to see that no leak down test can be done with out that o ring being in good shape. All the other covers have a gasket or o ring to hold in the pressure but the right side cover is open to allow for the actuator rod. Now just need to find a square cut o ring
The o-ring on the outside of the guide is just a regular o-ring, on the inside it's a small lip seal that seals between the guide and the shaft. The sizes are listed on the parts page that Jason posted, which allows you to source them from a local bearing supply house.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Do you have a 125, 200, 250??
If you can't put it in your thread, please put it in your signature. Thanks.
- Country: thailand
Mine is a kdx220 1997. That parts diagram is different to mine. O ring on the exhaust rod is a square type o ring with a shallow groove in the middle
In this picture are you talking about the 92049 or the 43049? The 92049 are oil seals and are included in a Tusk top end gasket set. The 43049 is called "Packing" on a parts list and is the oring that goes onto that right side shaft. Its not included in a Tusk top end set. The 92049 have a groove on the back of them like any other oil seal.
Oil Seal 92049-1238 Qty 2
Packing 43049-1076 Qty 1
Unless the 220SR cylinder is different, those are the Kawasaki part numbers
- Screenshot (58).png (546.28 KiB) Viewed 4318 times
- Screenshot (66).png (409.1 KiB) Viewed 4318 times
two meme response is in order:kdxdazz wrote:Mine is a kdx220 1997. That parts diagram is different to mine. O ring on the exhaust rod is a square type o ring with a shallow groove in the middle
I see what you're saying now. Are you talking about the 49006 rubber boot?kdxdazz wrote:After I dummy assembled it it's easy to see that no leak down test can be done with out that o ring being in good shape. All the other covers have a gasket or o ring to hold in the pressure but the right side cover is open to allow for the actuator rod. Now just need to find a square cut o ring
- Screenshot (68).png (354.52 KiB) Viewed 4305 times
- 6 Riders
Pretty sure he's talking about 92049John_S wrote:I see what you're saying now. Are you talking about the 49006 rubber boot?kdxdazz wrote:After I dummy assembled it it's easy to see that no leak down test can be done with out that o ring being in good shape. All the other covers have a gasket or o ring to hold in the pressure but the right side cover is open to allow for the actuator rod. Now just need to find a square cut o ring
- Country: thailand
Thank you kindly. The 43049 is the one I am talking about. Is that only a Kawasaki part. How did you post photos on this forum. If I knew how to do it I would be more clear with my question
