First kdx have some questions
99 out 100 times it will be the right side crank seal. The other 1% would be between the case halves or a case half has a crack. You need to do a leakdown test to know for sure.
Re: First kdx have some questions
Thank for your response, anyway it is getting sucked through power valve also?
Impossible through the powervalve.
[/quote] Thanks for the specs. Can you look up the reed tolerance spec for me? I haven’t took them off yet but suspect this causing my rich condition[/quote]
Reed warp service limit .2mm.
