Clutch slipping
Clutch slipping
Postby Fxr84 » 07:55 pm May 15 2018
Clutch slipping when bike gets on the pipe, have new cable running kawasaki 10-40 oil, thought was the cable when replaced having same issue as soon as gets on high end clutch slips, not getting all of the top end
Fxr84
Has thanked: 0 time
Been thanked: 0 time
Re: Clutch slipping
Postby Jason » 08:14 pm May 15 2018
Clutch springs OEM or aftermarket?
Old or new?
Tension OK on springs?
Thank you, Julien D for all your hard work!
PLEASE! Do not "dip" PWK Keihin carbs in Berryman's to clean them! It will damage the internal o-ring (jet block gasket).
Jason
Images: 12
Has thanked: 129 times
Been thanked: 341 times
Re: Clutch slipping
Postby jjavaman » 08:40 pm May 15 2018
You could try ATF type F. Maybe try sanding the fibre plates?
jjavaman
Images: 0
Has thanked: 15 times
Been thanked: 13 times
Re: Clutch slipping
Postby Fxr84 » 08:54 pm May 15 2018
All Oem all within spec, basket isn’t grove, strange that is ok low but when pwr come on it doesn’t want to get all the motor is laying out
Fxr84
Has thanked: 0 time
Re: Clutch slipping
Postby Jason » 10:04 pm May 15 2018
Just for fun... :razz:
WHICH KDX are we talking about??
Jason
Images: 12
Clutch slipping
Postby SS109 » 02:23 am May 16 2018
Do you have the proper free play at the clutch lever?
AZ State Parks OHV Ambassador - Trail Riders of Southern AZ
'11 GasGas EC250 Race
Images: 10
Has thanked: 62 times
Been thanked: 86 times
Re: Clutch slipping
Postby Fxr84 » 04:15 am May 16 2018
220 and the free play is good
Fxr84
Has thanked: 0 time
Clutch slipping
Postby SS109 » 05:59 am May 16 2018
What did the frictions and steels measure out at? How about the spring measurement?
Images: 10
Re: Clutch slipping
Postby Fxr84 » 08:31 pm May 16 2018
Spring 36, fric 2.1
Fxr84
Has thanked: 0 time
Clutch slipping
Postby SS109 » 05:00 am May 17 2018
So, your clutch isn't within spec.
Spring free length = 38.7mm - service limit = 37.2mm. Yours are 1.2mm under minimum spec - Replace the clutch springs.
Frictions thickness = 2.92 to 3.08mm - service limit = 2.73mm. Yours are .63mm under minimum spec. - Replace frictions
That explains why it won't handle the power. Also, with the info you provided, I would bet the steels are under spec and need replacing as well. Easy job.
Images: 10
Re: Clutch slipping
Postby Fxr84 » 05:18 am May 17 2018
Thanks for reply, I’m ordering new clutch pack many have noted going back to oem for clutch pack, next question I know this has been gone over million times, I use recommend oil in case should I stick with it or is there a better oil to run, ie rotella, I never ran it in any of my bikes ,all trail riding.
Fxr84
Has thanked: 0 time
Clutch slipping
Postby SS109 » 07:04 am May 17 2018
Oil is totally subjective. I personally run ATF in all my bikes and love how it's improves shifting feel. My best friend loves Rotella and it has served him well. The only thing everyone agrees on is never use a standard automotive oil in your bike as they have friction reducers that can actually cause your clutch to slip. So, good luck making a choice. :mrgreen:
Images: 10
Re: Clutch slipping
Postby Jason » 01:44 pm May 17 2018
Do you own the OEM service manual or subscribe to the Cyclepedia manual?
Jason
Images: 12
Clutch slipping
Postby jjavaman » 11:52 am May 18 2018
+1 on the ATF type F. Inexpensive and works great. I also put the full litre in it, seems to quite down the rattling :)
jjavaman
Images: 0
Return to KDX General Q&A
Who is online
Users browsing this forum: No registered users and 9 guests
cron
