newbe
The best silencer for the stock pipe is the stock silencer.
You can go to 40:1 at any time.... it's not that big of stretch. But, I would get it jetted right when you change. It affects the jetting but I imagine your jetted rich if you have stock jetting.
- kawboy2006
yep just as inda said I however own an 06 and I would recomend you change the pipe before if not at the same time as the silencer.the pipe will give the biggest bang. as for which silencer where you gonna ride woods etc. you'll need a silencer with an approved arester for most areas, or if your more of the closed course kinda rider you can go with a open silencer say the fmf powercore II. also remove the snorkel from your airbox lid, that'll let the engine breath better and add a couple more ponies. also no matter your riding skill or weight that kdx's suspension is so off balance its almost a crime they sell em like that. check kdx exposed section at jeff fredetts website found in the links above you'll not only find out more info on your original question and the fact at least i found out that no jetting changes are nessasary after the pipe/ silencer switch. I run 32:1 and what was rich seems right on now. but more into the suspension. until then be safe and dont go into any corners too fast.
2006 kdx200,
- tim
A pipe would be the first purchase after jetting and suspension work. The only drawback on the stock silencer is weight.... oh yeah, and it's ugly!
jeff's site
03 kdx/kx200... my lil woods weapon
07 zuki ozark250...xmas present for my son
- tim
- KDX220PHIL
- kawboy2006
dont forget that suspension work !!! the front spring rate is way to soft for ya with gear on and all compounded by the rear spring being to stiff making the front even worse. notice the way it dives into corners and seems to nose dive off the littlest jump thats the spring rates working against ya. brake too hard in a corner and you'll be pickin sand out your shorts. then go for the pipe, jeff fredeete says no jetting changes are nessasary on the newer h models with the pipe silencer upgrade but that candpend on elevation temp etc. I didnt change a thing jet wise and seems fine by the way its running and plug condition. just my opinion of my 06
2006 kdx200,
The factory jetting changed in the 'newer H' models?
What is it now? In the '06 200 'fer instance............
If your situation is rare...how much is it worth?
...cuz I had the 'zact same situation. Which is why my lid is on!
I don't rag on about it..'cuz there are no-lid'ers that are convinced their way is the right way.
It's just you'n me that know differnt, 'eh?
I didn't like the noise neither..........
I haven't heard of somebody with a 220 having a problem with no air box lid on, but have heard of a few with 200Hs having a problem. The only reason I mention it is because I spent many hours and many $$$ over a time period of more than a year to find this solution. I'm just trying to hopefully save some other poor sap from going through the same thing I did just to find out that the simplicity of an air box lid was a big deal for proper jetting. I felt a little stupid when I finally figured this out, but the serendipity of learning a ton about jetting (and timing, and compression, and.......etc) during all of that experimentation maybe made it worth it (at least that's what I tell myself :-) ). To the guys that can run without an air box lid and have good jetting with no hesitations or flat spots, I say, More Power To Ya!!!
'95 200H
- kawboy2006
