kdx 220 03 cylinder coolant plug!!
- Country: QUEBEC
i guys i want to know if the kdx have a drain plug on the cylinder for removing the coolant?? Or you just have to remove the drain plug on the water pump and the radiator cap. I have a cr 80 2001 too and on the right side of the cylinder you have a screw for removing coolant in the cylinder but i dont see this on the kdx..
KDX 220R 2003 & CR 80R 2001
Re: kdx 220 03 cylinder coolant plug!!
To drain the coolant you pull the drain bolt on the bottom of the water pump. There is a screw on top of the water fitting on the top of the cylinder that is used for bleeding air when refilling.
- Country: QUEBEC
thank you bufftester for your reply!! really appreciate!
so all the coolant in the engine will be removed and in the cylinder too ?? the engine will be completely empty??
No, it won't drain every drop of the coolant but like 99% of it. However, for all practical purposes, yes, it will be drained.
- Tyl3r
Yea, the bottom of the water pump is the lowest point of the coolant system.
- Country: QUEBEC
ok but on my cr 80 2001 u have a screw for remove the coolant in the cylinder too, but on the kdx i dont see one so i just have to remove the drain plug on the water pump and the radiator cap and all the coolant will be removed.
imm okkk ??
imm okkk ??
- Tyl3r
There is another plug in the cylinder, right above the pipe outlet... but I don't think that was ever intended to be a drain plug, rather a hole to help remove the core in the casting. The water pump is lower than this though and everything will come out there... no extra plug in the cylinder that needs removed.
- Country: QUEBEC
okk thank you all for your answer!! that really help me !!
put an air hose in the bleed nipple on top of the head, and pull the drain bolt... it'll empty it alllllll out in a hurry
LOL
Does anyone make a replacement for that cylinder plug(set screw)? I was given a 95 KDX 200 that sat for a few years and that set screw rusted out and is leaking.
If I recall correctly it's a standard metric thread so any bolt that has the same thread and head diameter should work.
The bleed screw on top of the cylinder is an M6 (6mm bolt 10 mm in length) standard metric thread
Do a search on here. Someone figured out the dimensions. It is around 16 mm x 1.5 mm, something like that. I can't remember.
EDIT: Yep...
viewtopic.php?p=189175#p189175
EDIT: Yep...
