I have recently noticed that when trying to kick start my bike the gears won’t grab but half the time and makes starting a pain. I have not taken anything apart yet, and was hoping someone could tell me exactly what I need to order. I usually order from Rocky Mountain Atv just because I can order the parts I need instead of the whole assembly. Any advice would help being I’m a amateur at working on bikes.
Thanks
Kick Starter on 99 kdx 200
Re: Kick Starter on 99 kdx 200
Examine the following:
kickstarter spring
ratchet
kickstarter spur gear
https://www.partzilla.com/catalog/kawas ... -mechanism
one of the cheaper places to buy OEM parts
kickstarter spring
ratchet
- Molly's 70
If it were me, I would drain the oil & remove the clutch cover. Then you can get a visual inspection of what is going on. Just guessing, maybe the spring behind the ratcheting mechanism failed.
Check for worn teeth. They wear down over time. There is a "kickstart only catches some of the time" thread here every few months.
Thank you guys for the help. This forum is awesome and is very helpful. Thanks for the advise.
