I was contimplating on changing my fork oil. I did a search but turned up nothing on how to do this. What special tools are needed? I have the oil, just no idea on how to do this. What level or how much oil is recommended on the re-fill?
I'm also going to change the seals myself in the spare forks I have. What besides the seal driver do I need? Is there anyone who has made thier own home made seal driver? What was used?
How to Change Fork Oil
- m0rie
Check out the sticky about KYB fork disassembly in the USD forum. It should give you the low down.
- Ryan
I've been reading through the KYB overhaul instructions. I have a question. Since I'm just changing oil on the forks, what steps are NOT necessary in this process?
I plan on changin the seals myself on the extra forks I have. I have the seals already, so where does the seal driver come in? I don't remember them refering to it in the instructions.
- m0rie
The absolute minimum would be steps 1-6. I'd take off the compression assembly at the bottom of the fork as well to get out the gunk that tends to build up there.
- m0rie
The seal driver is to drive the oil seal into place in the fork. Since its not mentioned anywhere in the article you'll need a 14mm allen wrench or hey key socket to remove the compression assembly. Flip the forks over and compress them. The resulting spring tension will let you remove the compression assembly without having the fork holding tool.
"....all i did was make it (seal driver) long enough so i can bang it with a hammer. "
You can make a seal driver out of PVC or aluminum or steel and likely a number of other materials - However something is wrong if you have to 'bang it with a hammer' plus the damage that may occur to your fork tube and/or seal.
Driving in the seals is performed by sliding the "seal driver" up and down the fork inner tube by hand. I like to lightly tap the seal (with the seal driver) to get it started into the outer tube then progressively increase the sharpness of the tap until the seal is full seated. Maybe 4-6 taps of which 2-3 may be considered sharp taps with the seal driver.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
