goatrider wrote:Thanks John. Still no posts from those that have experienced KIPS gumming in woods Just those that predict it will or might happen. Really folks?. If you have no knowledge, then please shut up. If knowledge , please chime oin.
You asked about the oil, and we're giving you our knowledge of the oil..... what's the problem? Just because some of us don't use it personally and have direct experience with that particular oil, doesn't mean we haven't researched different oils or have no knowledge of it. The reason I don't use it and don't have direct experience with it, is because I DID research many different oils before picking one, including the 927, and came to the conclusion that there were better options available. There's a lot of variables involved here..... riding area, temp, humidity, riding type, ratio, quality of gas, ethanol vs non ethanol, if the bike is warmed up before riding, jetting, etc... the list goes on. No 2 bikes are gonna be the same. Is everybody that uses this oil going to have problems with the power valve gumming up? No, of course not. Like I said earlier, it IS a good oil, and it's been around for a long time with many faithful users. But in that research I did still see a very common pattern of one particular thing, with this one particular oil.... power valves gunking up. And most of them were in the conditions I described.... slower woods riding. It became evident that it was indeed a very common issue with this particular oil, not just in the KDX but many different types of bikes. That was enough for me to scratch it off my list, since there are other great oils out there which, from reading reviews, don't seem to have this problem. There was no point in trying something that may or may not have a known issue down the road, when I could just pick something else that didn't have that issue. Sure some people may have great luck with it.... I'm not discrediting SS109's review in the least..... if he's had good luck with it then that's great, and I'm glad he's had good luck with it. I'm sure many others have as well, even in KDX's. But the fact still remains that this IS a common issue with this particular oil. Some may have a problem with it, some won't..... too many variables to say whether you will or won't, but again the fact remains that it IS a common issue, when you look at the big picture instead of just a handful of people that have used it. And that's exactly what we're trying to tell you here..... that you might run into this problem using this oil. It doesn't mean you will.... none of us can predict the future, just that the possibility is there. It doesn't mean that everybody that uses it will have a problem just because some do, and it also doesn't mean that you won't have this problem just because some don't. We're just making you aware that it is a possibility down the road due to it being a known common issue with this particular oil
Use what you want.... I honestly don't care. If you have it and want to use it, then just use it. But you asked what we knew about it, and we're telling you what we know. Relax.... we're trying to help you here. Go read some reviews for yourself if you don't believe us
