Anyone using the Pro Taper Se bars and bark busters or similar?
I am wanting to replace my stock steel bars with 7/8 alloy bars and I want them to fit my alloy mounts for my probends. The alloy mounts are .525" Dia.
The SE bars specicy a 5mm wall thickness, if it is 5mm at the grip area then the ID should only be .481". Not enough room for the alloy mounts intended for aluminum handlebars.
Anybody know if the wall thickness is smaller at the grip area?
Pro Taper Bars + Cycra Probends.
- KDX220PHIL
- KDX220PHIL
