shifter shaft in/out movement
bws2
Post by bws2 »
I have a 2001 KDX200.
I was tightening the shift lever and noticed that the shifter shaft
has some movement in (towards the case) and out (away from the case).
Can you guys tell me whether this is normal or is it and indication of a problem?
Willbilly
Post by Willbilly »
How much movement? I have about 1mm on a fresh shift shaft, I'd think that is okay
bws2
Post by bws2 »
Willbilly wrote:How much movement? I have about 1mm on a fresh shift shaft, I'd think that is okay
Thanks for the reply Willbilly.
It's not a ton of movement. I'm guessing between 1-1.5mm.
Re: shifter shaft in/out movement
I seem to remember around that much wiggle room, too.
