Output shaft seal leak
Posted: 12:26 pm Jan 15 2017
by seniorsehas
I've replaced the ouput shaft seal, collar and 2 o rings twice. They're leaking like crazy. Anybody ever have this bad of luck and if so what did you do to fix it? Thanks in advance!
Re: Output shaft seal leak
Posted: 01:35 pm Jan 15 2017
by doctord23
It sounds like you have changed the sealing surfaces.
Check the breather tube and make sure that it is clear and not allowing pressure to build up.
Also clean the surrounding area and make sure that there is not a crack in the case. If a chain let loose at some point, that can damage the case.
Last thing to check would be a bad bearing on the output shaft.
Good luck.
Posted: 04:56 pm Jan 15 2017
What circlip and what front sprocket?
And if you want to let us in on a secret like... WHICH KDX, that would be great too
