Exhaust Bang/Knock
Posted: 11:26 pm Dec 13 2016
Hiya.
KDX220. Just had cylinder replated and new piston. Got an erratic knock sound coming from exhaust ONLY on deceleration from anything but low revs. Knock, knock... knock... knock... knock, knock, knock... etc. Plenty of random gaps in between the knock sound.
Clutch in and sound goes away. Hit kill switch and sound stops. That makes me think non-mechanical and gas flow/load related.
Have leak tested engine, checked exhaust header to manifold / tried a clip richer on needle along with much air screw faffing - no bad problem / no change.
If it did this before the re-plate and new piston, it sure wasn't as obvious... Ideas?
(At a guess - porting affected by replate? Also, 'Exhaust Bang' on 2Ts seems to be a common occurrence - some say not to worry about it. Looks like some fix by going richer/leaner or by changing cylinder base gasket to alter squish.)
Cheers.
Cheers.
