Oil seal leak ... Gear change shaft.
- Country: France
Hello.
I have a gear shift shaft oil leak on my 200-E1. Do you think it's possible to remove the seal and replace it without splitting open the engine ?
Thank you very much for the advice.
It shouldn't be too difficult to remove ...
You can either gently tap a sharp flathead screwdriver between the outer seal collar & the engine case & prize the seal off .... Or screw in x2 small self tapping screws into the metal collar & pull / work the seal off the gear shaft ....
When fitting the new oil seal make sure the gear shaft is clean of dirt & rust .... Apply some grease around the lip of the new seal before installing .
- Country: France
Re: Oil seal leak ... Gear change shaft.
Thank you cornishwrecker for the piece of advice. I'm gonna work it out !
I learned the hard way that it is so much better to just get the $5 seal puller from harbor freight. It's a thin pry tool. I spent two hours trying to do the screwdriver / screw thing without gouging the countershaft. It didn't work. I then got the tool and was done in less than 5 min.
- Country: France
I'll try to get one of these ... If shipment to europe isn't prohibitive. Thanks again !
I tried to delete that comment. I mistakenly thought you meant the countershaft, not the shifter shaft. I have no experience with the shaft you are trying to change.
- Country: France
Hopefuly it will work the same !
It;'s exactly like this one. This is in UK. I'm not saying it will work. But maybe somebody can chime in.
- Country: France
