Stuck in high RPM
Stuck in high RPM
Hi guys/girls! New to this forum need help! I ahve a a 1990 KDX 200. Yesterday i was riding with a couple buddies for and hour. Had no problems until out of no where my bike reved really high and stayed like that. The bike has no problem starting but as soon as it cranks over it revs really high until i hit the kill switch. Please help guys
Re: Stuck in high RPM
Cable could be sticking or the carb could be dirty causing it to stick.
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
Cleaned out the throttle cable on the handle bars. And i cleaned the carb about 3 weeks ago. Im stumped :(
- KDXohio
Welcome to the forum!
First make sure the slide isnt stuck wide open then if its not definitely pull the carb and clean it again could have picked up some more dirt from the tank. Thats where I would start.
What is this "slide" that youre mentioning buddy?KDXohio wrote:Welcome to the forum!
carburetor throttle slide
beyond that, air leak
- KDXohio
Are you almost out of gas? Mine does that when I'm running low.
Sent from my SM-N910V using Tapatalk
Stuck in high RPM
No i had gas. That was the first thing i thought. Im going to go ahead and take this carb off and check the jets and that throttle slide and pin to see if they are ok. Ill keep you guys updated. *thank you*
I had a similar problem with mine and it was fixed by a simple and quick carb cleaning.
Most likely a stuck slide as mentioned above. Pull the carb and clean it while you've got it off, its a 30 minute job.
Stuck in high RPM
crank seal ignition side.
Stuck in high RPM
If it's not the slide, you might have an air leak.
Cau one of you guys please explain how to post a picture on this forum.
- KDXohio
create a Photobucket account upload the pictures that you want to post 2 Photobucket then copy the IMG link and paste it in your message here
