Mark W wrote:
1) quick guitar story for you.
2) I read that you have owned both the desert and the woods pipe on your kdx 200. What differences did you notice between the two pipes?
1) That's a neat story. Les Paul is one of the giants. I'm a Fender guy, myself, but I have a Les Paul, too. Every body's gotta have one!
2) I like the desert pipe better because my terrain is more open. Even when I hit the woods, it's open jeep trails with very little 1st gear picking around. I'm usually running 3rd-4th gear (I'm geared down, though: 13/50). The torque pipe is just like everyone says- low/mid. No hit to it, it just kind of smooths out on top. I really didn't think the low was all that impressive, myself. After riding the Torque for 3-4 years, I finally got a Desert and WHOOOOAAAA!!! There's a whole 'nother KDX in there! I didn't miss the low end at all, and when I'm playing around in the creek, I do a lot of 1st gear "climb the wall" "crawl thru the rocks" kind of stuff, so I DO use low-end sometimes.
What I noticed is that the bike really comes alive at 1/2 throttle. Someone said it feels like a 125 with bottom end, and I think that's an excellent statement. It revs faster (not like the KX, but lots faster than with the torque pipe) and clutches much better now. I really noticed a difference on my play track where I can clutch at the base of a jumps and accelerate up them. With the torque pipe, I had to get a run at them and it couldn't do the "Supercross snap" at the base.
I thought I might be switching pipes for different terrain, but so far, I've had no inclination to do so. After running the Desert/Rev for awhile, I went to Boyesen Pro reeds (replacing stock 1 piece reeds) and that made the hit even more controllable. Without them, wheelies are a little tricky 'cause the bike comes on the pipe fairly hard. With the Pro reeds, this was smoothed out and I felt much more comfortable pulling a power wheelie and am able to control the front wheel better with the throttle. I also put 2 pipe gaskets in as a home-made torque spacer, and that helped bottom end a little.
Result of all this, is that the bike pulls very well on the low end right off idle, has a little bit of a dip about 1/4-1/3 throttle, then starts coming on the pipe at 1/2 throttle and carries power up to nearly full throttle. This powerband works fine for me because it gives me a) an area down low where it pulls, b) a smooth area where I can putt, and then c) an agressive area. For comparison, the KX125 lacks (a) and an XR250 is all (a) and nothing else.
