Rear skock Sag and Static Sag questions.
Posted: 02:37 pm Dec 27 2005
well I went ahead and adjusted the Race sag on my bike yesterday per the Team Green instructions. It was'nt to bad until it was time to adjust the Static Sag. Team Green recommends 100 mm race sag. I achieved that. It was when I went to adjust my static sag that I ran into a delima. They recommend 30-40mm static sag. I am at 19mm of static sag. according to the directions, my spring rate is to soft? I'm running the stock spring, and I weigh in around 215 lbs. without riding gear. I did wear boots, helmet and roost guard when setting the race sag also.
So what do you guys think? Try it like it is or lose weight and reset the race sag? ????????????? Any opinions?
Would the dampening settings have an effect on either sag measurments? I have mine set up pretty soft. I think it's around 7-8 (counterclockwise) clicks from "0" clicks meaning the screw is bottomed out (clockwise).
