96 kdx premix instead of oil pump
Posted: 09:54 pm Feb 26 2016
by joncf1997
I have a 1996 Kawasaki kdx 200 I was wondering if I can just pre mix instead of using the oil pump or if that would hurt something in the motor. Any suggestions will be helpful.
Sent from my SCH-S968C using Tapatalk
Re: 96 kdx premix instead of oil pump
Posted: 01:16 am Feb 27 2016
by jjavaman
I never knew kdx's had pumps??? If yours does, it should be fine to block it off and use pre mix. Where are you from?
Posted: 05:22 am Feb 27 2016
by koshari
My old SR had a pump. Just make up a plate to go over the pump hole and itilise the 2 screws that mounted it. You will also need to block the tube on the reed cover.
Posted: 07:41 am Feb 27 2016
by joncf1997
Corinth Mississippi
Posted: 07:42 am Feb 27 2016
by joncf1997
And thanks
Posted: 07:43 am Feb 27 2016
by joncf1997
by joncf1997
Posted: 10:58 am Feb 27 2016
by diymirage
any chance you can post a few close up pictures of the oil pump ?
ive never seen an SR model up close, and all of my KDXs just run premix
Posted: 12:08 pm Feb 27 2016
by sarrant
That's not an SR. That's an H-Series.
There is no oil pump. Premix only.
Are you by chance putting oil in the coolant overflow tank? It does look like a Yamaha oil injection tank.
Posted: 09:22 pm Feb 27 2016
by joncf1997
Posted: 09:24 pm Feb 27 2016
by joncf1997
Posted: 09:25 pm Feb 27 2016
by joncf1997
Here's a picture of my old 1996
Posted: 02:48 am Feb 28 2016
by koshari
Sarrent is correct. You have a periphial framed bike. The SR was based on the earlier models. I suspect you are indeed speaking of the coolant reservoir.
Posted: 04:52 am Feb 28 2016
Please tell us that you did not run the engine on straight gasoline.
That little tank is for the coolant reservoir.
Posted: 07:57 am Feb 28 2016
by Tedh98
Jason wrote:That little tank is for the coolant reservoir.
Or in this case it could be a water pump seal lubricator.
Posted: 11:11 am Feb 28 2016
by joncf1997
No I didn't even crank it. Thanks for the info.
Posted: 11:12 am Feb 28 2016
by joncf1997
I was just wondering what it was before i mest something up.
Posted: 01:16 pm Feb 28 2016
FREE download of the 1996 KDX200 owner's manual from the Kawasaki website:
http://www.kawasaki-techinfo.net/showOM ... ng_code=EN
Posted: 04:41 pm Feb 28 2016
by diymirage
joncf1997 wrote:I was just wondering what it was before i mest something up.
like pointed out by now, what you are looking at in in fact the radiator overflow reservoir
if your mechanically inclined, just pull that shroud of and have a good look at it
the way the lines hook up to the radiator are a dead give away....as is the writing on the cap
still, points for asking what is what before assuming and wrecking a good bike
