Muffler retaining bolts
KanuckKDX
Post by KanuckKDX »
There are three bolts holding the muffler to the frame. Rubber grommets around these allow some vibration I think ( the bike is at the shop so I am using memory).
Each costs $20 CAD and all of mine are kaput.
Has anyone found a cheaper solution than buying OEM replacements?
KanuckKDX
'01 YZ426F son's
'02 XR400 still for sale
'04 KTM 450exc it's all about the e-start
m0rie
Post by m0rie »
Mine were gone when I got the bike. I've used a single solid mount bracket since i've had the bike.
kdxquebec
Post by kdxquebec »
yes you are right.
I pretty sure you will have to buy oem. Thats what I did. Mine were kaput too!
Morie- do tou feel a lot of vibration? Do you have 3 solid bracket on the pipe?
m0rie
Post by m0rie »
Are you talking about the pipe or the muffler? The muffler has two mounting holes that are supposed to have rubber gromments with a bracket thru each. Both are gone on my bike. The end one I replaced with a metal solid bracket. The pipe has three mounting tabs. All of the rubber dampers were busted on my bike, I had drilled them out at one time so they could be solid mounted. I replaced them with new rubber dampers and they reduced the amount of vibration and noise by quite a large amount.
kdxquebec
Post by kdxquebec »
I am talking about the pipe not the silencer.
thanks.
I think kanuck talk about the pipe too?!
KanuckKDX
Post by KanuckKDX »
I worried about solid mounting them.
I think it's the muffler that has three rubber mounts. But in any case that's what I was talking about after looking at the microfiche.
I am going to order one new mount and then see what I can create using rubber for the other two.
KanuckKDX
'01 YZ426F son's
If it's the silencer:
I made my own. Take the thing to your local hardware store along with the fasteners and fix it!!
I used a split (grooved) grommet sort of thing..a ferrule of the correct diameter to fit the existing hardware..done!
If it's the pipe? Good luck! OEM, I think. Yeah.,.they are expensive. If they don't fit too good, you probably need to tweak your pipe for a better alignment. That's a lot simpler (to bend the pipe) and harder (to get it to FIT right) than you might think.
