1986 KDX200 Ign, coil compatibility
Rodeo
Post by Rodeo »
Could anyone tell me what ignition coil will work on a 1986 KDX200? Would a 1989-94 work?
Thanks in advance! :grin:
KDXohio
Re: 1986 KDX200 Ign, coil compatibility
Post by KDXohio »
I dont know 100% but most ignition coils are the same ive used a lot of different ones between bikes without problems
sarrant
Post by sarrant »
You may have to finagle the mounting, but one off nearly any dirtbike should function.
hbgod
Post by hbgod »
you can buy new ones from ricky stator
If you ain't Mixin Gas, You ain't Haulin Ass!
