My KDX is louder than yours
Posted: 07:15 pm Aug 29 2015
by kneekicker
I have replaced O rings and even used some high temp gasket sealer and I still have a big leak up front.
Could pipe be tweaked enough that I am not getting a good seal? (FMF Gnarly BTW)
Some one told me that they have seen exhaust port on cylinder get worn...I find this hard to believe and hope its not the case for me.
Any help will be grateful.
Posted: 07:53 pm Aug 29 2015
by Adamnb1
are both springs on and providing good tension? Do you have a brass ring between pipe and cylinder ? I didn't even know there was supposed to be one until I got my last top end kit.
That being said, without the ring I had no leak there.. so perhaps you have a tweak, as you said.
Re: My KDX is louder than yours
Posted: 07:58 pm Aug 29 2015
by kneekicker
Yes, I forgot to add that I put in new brass ring and springs.
Posted: 03:22 am Aug 30 2015
Yes, the exhaiust port can get worn. Steel beats aluminum in an abrasion contest.
Also, yes, it could be a bent pipe not allowing it to seal properly. Beyond that, perhaps your other pipe mounts are bent / misaligned somehow.
Posted: 08:19 am Aug 30 2015
by C George
Coat the pipe with Permatex Rt. Stuff before inserting into exhaust port.
That will also eliminate ANY wear of the steel pipe in an aluminum port.
This will dry like a hard rubber , I'm not a fan of truely hardening sealers for
this type of application , too much vibration.
Posted: 05:34 pm Aug 30 2015
by KDXohio
C George wrote:Coat the pipe with Permatex RT
First post said he tried that
May be able to get a machine shop to put in a sleeve to get the exhaust port back to the right size
Posted: 10:42 pm Aug 30 2015
by Jaguar
maybe it is jetted too rich as well as not sealing well at that juncture
Posted: 07:56 am Aug 31 2015
by C George
KDXohio wrote:C George wrote:Coat the pipe with Permatex RT
Permatex Rt. Stuff is a totally different animal than " high temp silicone "
Posted: 08:40 am Aug 31 2015
by KDXohio
Are you talking about the red permatex rtv?
He said gasket sealer so im assuminghe meant the red or black permatex but i could also be wrong
Posted: 04:30 pm Aug 31 2015
by chippy
Permatex Right Stuff gasket maker is what he is referring to.
Posted: 12:58 pm Sep 01 2015
by Slick_Nick
I use Permatex copper sealant. It's meant for high temperatures. Says right on the tube suitable for exhaust components.
Posted: 08:42 am Sep 02 2015
by KarlP
If your pipe or hangers are bent it won't seal well.
The thing to do is check fit first. Put the pipe on, no silencer and no sealent and make sure it is square in the cylinder. The pipe hangers get tweaked and when you hook them up it can pull the pipe out of square. Keep tweaking on the hangers until the pipe seats nice and is square with the cylinder, THEN take it back off and apply the Permatex. Let it set up overnight and then see how the silencer fits. It is easy enough to bend the length of pipe coming out of the silencer so that it does not pull the pipe when mounted.
