Bar risers
Bar risers
What are the advantage to bar risers and how tall should I go or are they a standard height. Thanks
- Sullyfam
Re: Bar risers
Others might, but the only advantage I know I is they allow you to be in the proper position while standing. Usually taller people get them to avoid being hunched over.
- KDXohio
Re: Bar risers
They let you slide your forks up higher if you do a front end swap they're used for fat bars too a lot of times.
- Sullyfam
Re: Bar risers
Yeah...those too [emoji2]KDXohio wrote:They let you slide your forks up higher if you do a front end swap they're used for fat bars too a lot of times.
