i have a E roller (suspension, wheels, frame) but no engine in it
and
i have a H super sexy beast-mode 220.
the spring on the H is grey, the spring on the E is blue. i wonder if either shock is considered better, or if either spring is more suited to tight trails (not motocross!) for an old fat guy (218 lbs) that ddoesn't care about going fast ?
thanks !
E shock vs H shock - which mo bettererer ?
Very similar shocks, just with different reservoir orientation for their respective frame configurations. They're not interchangeable due to the resorvoir/frame relationship. I believe the silver spring is slightly stiffer.
Re: E shock vs H shock - which mo bettererer ?
Thanks, I may change springs to see which I prefersarrant wrote:Very similar shocks, just with different reservoir orientation for their respective frame configurations. They're not interchangeable due to the resorvoir/frame relationship. I believe the silver spring is slightly stiffer.
the E is 4.6 and H is 5.0. You probably need 5.2 or so.
