Where to buy pwk jet holder oring seal
I need the seal that goes between the main jet holder and carb body, i found it on ebay but the guy is away until July 30.thanks
Re: Where to buy pwk jet holder oring seal
i ended up finding it on jets r us, just so everyone knows, my oring was crushed and probably original, bike was running rich with a 140 main installed.
Yep, that's where I got mine from. I believe mine was destroyed when a PO dipped the carb.
I am suspicious that ethanol fuel is destroying these orings. I have had 4 carbs in the last 6 years that have needed to have this oring replaced. One of these was only 2 years old - a 36mm PWK AS on a 2012 KTM 250XC.
Ken Powell
2012 KTM 300 XC with YZ SSS cartridges in the WP tubes
2003 YZ265WR with 2005 AOSS forks
2003 KX125 / KDX200 motor with YZ SSS forks
First Motorcycle - 1963 Harley 175 Scat
doesn't the oil stabilize the fuel?kenpowell wrote:I am suspicious that ethanol fuel is destroying these orings. I have had 4 carbs in the last 6 years that have needed to have this oring replaced. One of these was only 2 years old - a 36mm PWK AS on a 2012 KTM 250XC.
I'm asking, not stating. :)
- Actionman
I chased a bog on my 02 200 for weeks and then took a look to find that o ring to be torn just enough to really cause a giant jetting headache. Id replace it IMMEDIATELY on ANYused bike that has a keihin pw carb.
2002 KDX 200
