Wheel balance
Wheel balance
Of course this question is geared to you plated KDXers but Do you balance your tires , Leave the rim loc out or just deal with it? Going to balance mine ,but was curious while I wait for my package to arrive. Thanks
- 6 Riders
Re: Wheel balance
I Just leave it alone. But I don't ride far on the street either.
- IDRIDR
Re: Wheel balance
I balance when a rim lock is installed.
2003 KDX 220. RB Carb & Head Mods. Desert pipe. She's a runner!
2006 KLX 250 w/351 big bore. A well-sorted dual sporter.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
2014 Suzuki DL1000.
- kx200
Wheel balance
If you don't need the rim lock for the street take it out. If you do need one add a 2nd one 180 degrees to balance it out. That way you won't need a ton of lead weights.
Re: Wheel balance
Has anyone ran No locks on there KDX? I would hate to turn a rim a rip a stem off.
Re: Wheel balance
I've run a KDX without a rim lock. While nothing bad happened, I wouldn't do it again because flat tires suck. If you spend a lot of time in the 40-60 mph range, you'll probably want to balance the tires.
