Reed valve arrow?
Posted: 05:43 pm Apr 29 2015
by ckelly33
Reed valve has an arrow on it, is the arrow supposed to tell me which way to put it in?
Reed valve arrow?
Posted: 06:37 am Apr 30 2015
by s10gto
Not sure on arrow ,but the rounded tab (A) on the cage should be on the lower left side of the engine/bike.
Reed valve arrow?
Posted: 06:45 am Apr 30 2015
by s10gto
Here ya go. Lower pic.
Re: Reed valve arrow?
Posted: 07:43 am Apr 30 2015
by Tedh98
If you put it in wrong, you'll be able to tell:
Posted: 10:01 am Apr 30 2015
by ckelly33
Mine has an arrow on the metal piece that if you put it in one way it faces down and if you flip it up and put it in it will point up. It'll go in either way. Also my o rings are worn out on the head pipe could that prevent it from running? Oil was coming out pretty significantly
Reed valve arrow?
Posted: 10:20 am Apr 30 2015
by s10gto
No if the pipe was missing it would still start.
Posted: 12:48 pm Apr 30 2015
by KDXohio
Probably fouled the plug try a new plug
