Clutch squealing...?
ethankdx
Post by ethankdx »
I replaced my plates and springs last season and ever since I have done so I hear a squealing while the engine is revving at high rpms and letting out the clutch slowly. Sounds like it is slipping or grinding. I've gone over the schematics and everything looks to be in order. I just recently replace the friction plates again and put some less stiff springs in it because I also had a really hard lever pull.
1991 kdx200
Any clue? Sorry for the lack of information this is all I know.
Cheers,
Ethan
cornishwrecker220
Post by cornishwrecker220 »
Are you running the correct ratio gearbox oil ?
Check the oil level as it may be too low. ?
Clutch bearing excessive wear ?
G22inSC
Re: Clutch squealing...?
Post by G22inSC »
Soak the plates before installing them?
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
ethankdx
Post by ethankdx »
I am running bel ray 75w. I recently rebuilt the bike a couple years ago, Whole engine. I noticed that the clutch basket will need to be replaced end of this year as there is a little bit of grooving starting to form but nothing to major, still is pretty smooth. I am wondering, maybe I am answering my own question. Could the clutch bolt that bolts down the basket be to tight? And the washer below the basket is rubbing which is causing a squeal? I soaked the plates ,yes.
cornishwrecker220
My friend once had a ktm 450 exc that did a similar thing....if you pulled away quickly there would be an awful noise coming from the gearbox ( similar to your front brake pads howling when glazed over ) it turned out to be a worn clutch & not much oil in the motor !
KDXohio
Post by KDXohio »
pull the basket out and file down the grooves the plates could be getting stuck on them
canamfan
Post by canamfan »
You mentioned the washer behind the clutch basket. That washer should be a thrust washer, it's possible it is worn from low oil or just years of wear.
