Barnett dirt digger clutch kit.
Posted: 12:27 pm Mar 25 2015
by cornishwrecker220
Has anyone fitted one of these kits to their bike ?
I have just purchased the full kit, however upon opening I noticed that 1 of the clutch plates is different from all the other Kevlar plates?
Any idea as to where I install it?
Toward the engine or furthest away ???
Re: Barnett dirt digger clutch kit.
Posted: 01:24 am Mar 26 2015
BIKE?????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
Posted: 05:21 am Mar 26 2015
by dingerjunkie
For clarification on Jason's question (if needed)...what model? What year? It doesn't help you if I've installed one on an '89 Suzuki RMX, does it?
Posted: 06:54 am Mar 26 2015
by KarlP
I'd suspect the Cornish Wrecker is on a 220, H model. Just saying......
The point about model/year is valid though.
Did the kit not come wih instructions? It would not matter to me, I always seem to have to assemble/reassemble clutches three times to get them to right.
Posted: 07:59 am Mar 26 2015
If that is the case, then that is indeed a cause for concern. How many plates are there? I know some KX125's have different plates in stock form.
Posted: 02:45 pm Mar 26 2015
Sorry guys...yes its for my 220, since having the bike `tuned` my clutch just cant cope with the extra HP even with EBC HD springs so opted for the Barnett Dirt Digger kit with Kevlar plates & stronger,longer HD springs
No instructions with the kit except for a `soak in oil before installation` sticker on the box.
The `odd` clutch plate I`m referring to has different `meat` on it compared to all the other plates in the kit, also with a larger diameter hole too..... hence me thinking
Emailed Barnett tech department & received a swift reply stating that the `odd` plate is installed last ,over the x2 steel rings
Job done ....haven't rode it yet but the pull on the lever feels stronger.
Posted: 12:52 am Mar 27 2015
Thanks for letting us know. My KX125 has a different inner and outer fiber plates stock.
Posted: 10:09 am Mar 28 2015
by BlackMist
Keep us in the loop how it performs
