HELP!
Posted: 02:10 am Feb 06 2015
by bone7615
I broke a ez out off where the case saver is suppose to be. I was extracting a broke bolt of course and bam 5 secs into it.I know that hole is useless now. Any ideas how to get a case saver attached without looking like crap.
Re: HELP!
Posted: 04:55 am Feb 06 2015
by ohgood
bone7615 wrote:I broke a ez out off where the case saver is suppose to be. I was extracting a broke bolt of course and bam 5 secs into it.I know that hole is useless now. Any ideas how to get a case saver attached without looking like crap.
take it to a machine shop, after you promise to never buy or use sleezyouts again. it might cost you 20$ or $100, and a lot of face palms from the machinist that fixes it, but worth every penny
Sent from my SAMSUNG-SGH-I547 using Forum Fiend v1.3.1.
Re: HELP!
Posted: 07:35 am Feb 06 2015
by GI_JO_NATHAN
Damn that sucks....
Yeah sometimes it's best to just do the right thing.
Re: HELP!
Posted: 08:01 am Feb 06 2015
by KarlP
There are two bolts that hold that case saver and the cover on, I believe. I don't think either bolt goes through to pull the cases together.
If it were me, I would consider cleaning up the area, grinding everything flush and flat, and JB welding that case saver on using the one remaining bolt. Not a great fix.
I hate EZ Outs almost as much as busted bolts
HELP!
Posted: 08:20 am Feb 06 2015
by canamfan
You know I always take the case savers off every bike I've had. I have never broken a chain but I have seen others that have broken a chain and then it wads up and rips the case saver off pulling out a chunk of the crankcase with it. Then you have a bigger problem, with oil leaking out. With out the case saver in place there is usually more room for the chain to ball up or sling it's way around if it breaks. If it does hit the ignition cover, there a lot cheaper then a case. Others may have a different experience.
HELP!
Posted: 11:23 am Feb 06 2015
by kx200
I too have never run a case saver, but I get a new chain every year too.
Re: HELP!
Posted: 02:39 pm Feb 06 2015
by bone7615
I never thought of that forget the case saver then thanks guys
Re: HELP!
Posted: 05:45 pm Feb 06 2015
by diymirage
never took one off and never broke a chain so I don't know if your better of with them or without them
having said that, if the good people at Kawasaki think I need a case saver im keeping them on
Re: HELP!
Posted: 08:11 pm Feb 06 2015
by AlexNGreen
Ez outs are a gimmick. Never had one work on a tough bolt. Left hand drill bits is where its at. Don't use cutting oil and use lots of pressure and slower speed for big chips that catch and turn the broken fastener out.
Re: HELP!
Posted: 10:42 pm Feb 06 2015
by Dekon
AlexNGreen wrote:Ez outs are a gimmick. Never had one work on a tough bolt. Left hand drill bits is where its at. Don't use cutting oil and use lots of pressure and slower speed for big chips that catch and turn the broken fastener out.
+1
Re: HELP!
Posted: 12:46 am Feb 07 2015
by bone7615
Rite on, I feel a lot better about my problem. I change the chain and sprockets every season anyway.
