Hi guys here is a strange for you,
I've finally finished my 97 kdx 200 project but run into a snag, when I start it cold with the choke it starts up with very high revs, after a while they slowly come back down, not sure what causes this but I don't like starting a cold motor like that,
motor fully rebuilt with all RB parts and carby new VForce 3 reeds FMF Gnarly pipe,
other than that loving the bike just haven't had a 2 stroke since I was a young feller.
Cheers Phil
Cold High Revs
Re: Cold High Revs
It's normal for it to rev a little higher higher on a cold start. Especially if it's been sitting for a while, or if you left the gas on.
Re: Cold High Revs
Thanks for that
yes mainly after sitting for a while
I think I have been leaving the gas on
Re: Cold High Revs
It is normal and likely will do it more in colder weather. You can turn the choke off immediately after starting and work the throttle a bit to keep it running.
In cold weather I'll start with choke, click it off immediately, and sometimes give it just a touch of choke for the first 15-30 seconds.
Re: Cold High Revs
Thanks guys I thought I might have had a carby issue,
still coming to grips with the 2 stroke.
Cheers Phil
Cheers Phil
Re: Cold High Revs
sir phily wrote:Thanks guys I thought I might have had a carby issue,
Cheers Phil
Sure thing! Just remember to turn the gas off when putting her away, pull the choke up, push it down once it's started and blip the throttle a little bit until it's up to running temp and then go rip!
