Is this how the mechanical seal and oil seal goes?
Posted: 05:34 pm Jan 03 2015
by superman27e
This is the mechanical seal and the oil seal for the water pump
Does the oil seal sit on top of the mechanical seal like this?
My service book doesn't say.
Posted: 08:05 pm Jan 03 2015
by superman27e
Ok, so from what I've been reading, that is wrong. From what I understand, I'm supposed to press the oil seal into the hole from the inside of the engine cover, so that the opened side of the oil seal is facing the inside of the engine cover. Then insert the bearing from the inside of the engine cover. The press the mechanical seal in the engine cover from the outside of the engine cover, then the impeller and nut?
Is this correct?
Re: Is this how the mechanical seal and oil seal goes?
Posted: 08:41 pm Jan 03 2015
by superman27e
Also, how in the world am I supposed to get the seal pressed inside the cover? I feel like I would break it.... Any tips on that?
Posted: 09:38 pm Jan 03 2015
by superman27e
Never mind, guys. I have the wrong oil seal. I needed 92049B, but purchased 92049.
Posted: 03:13 pm Jan 04 2015
by GI_JO_NATHAN
Well that sucks.
Posted: 05:59 pm Jan 04 2015
by superman27e
Yea, man..it really does. I'm gonna do a how to thread on changing water pump seals when the right seal gets here. Seems to be a lot of confusion on it.
Posted: 06:58 pm Jan 04 2015
by IDRIDR
superman27e wrote:Yea, man..it really does. I'm gonna do a how to thread on changing water pump seals when the right seal gets here. Seems to be a lot of confusion on it.
I was going to ask if you'd do one. Sounds like you're learning a lot hear which is a great opportunity to teach. Looking forward to it.
Posted: 03:42 am Jan 05 2015
by 6 Riders
I did mine right after I got my bike...took two tries to get the seals right. The manual just doesn't explain this very well. There is a thread on here somewhere where I explain how to do it. I wasn't smart enough back then to take pictures, but I'm sure I'm due for a repeat.
I know that the mechanical seal can easily be destroyed while pressing it in, so be careful when doing that....hell just order a 2nd one since you have to reorder the other seal...you'll probably need it
The other problem with the whole process is that the parts diagram is wrong. IIRC There are only 2 parts to the water pump seal and 2 optional parts. The optional parts are the bearing and the seal that sits "inside" the impeller. I replaced all of them, just because it's a smart thing to do when you have the inner cover off.
