Compression is only 120 on my 220
Do I need to rebuild now or can I get another season?
Re: Compression is only 120 on my 220
I"d say rebuild now. It's cheap, doesn't take much time, and the consequences of losing the motor isn't worth the $120 in parts and your time to rebuild it now.
I agree. $120 now or over $700 for piston and replate later. Thats how I look at it anyways.
- Tedh98
That is about double what it should cost!s10gto wrote:or over $700 for piston and replate later.
If the stock 220 piston is still in there than you should get it out of there.
On a 2000 you might be looking at replating anyway.
Sure should be about $250 tops for replate ,but if you explode a piston and cylinder needs to be welded ,bored , plated and ports cleaned up it can get up there quick. At that point better to find a used cylinder or fix it before this happens.Tedh98 wrote:That is about double what it should cost!s10gto wrote:or over $700 for piston and replate later.
I have bored many engines and some of these 2 strokes are not fun and require extensive set-up to be done right.
If a replate is in order
http://www.mt-llc.com/cylservice.php
Was the engine cold or warm when you did the compression test? Keep in mind that the 220 is a lower compression bike vs. the 200. The useable compression for the 220 is 90-150. 120 is right in the middle.
- kx200
my 1997 220 was at 150psi with the stock piston and over 7000 miles. At least look up the exhaust port and see if the rings show a lot of blow by.
- IDRIDR
My '03 220 with unknown miles and stock piston was 147 psi.
Replaced piston with Wiseco and about 20-30 miles of ring seating and its at 135 psi.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
2014 Suzuki DL1000.
