Water pump seal?
superman27e
Water pump seal?
Post by superman27e »
I noticed that I losing coolant pretty fast. I put some in the radiator yesterday, went to go riding today to noticed the radiator wasn't getting warm. I checked the coolant level, and it was way too low. Checked my clutch oil, and it was a very light grey color. I just put the oil in a few days ago, so it should still be the same color.
I know it's not the head gasket, because I just replaced that a few weeks ago. So, I've been looking, but I can't find a water pump seal anywhere. Anyone care to point me in the right direction? It's a 1999 KDX 200.
Gotanubike
Water pump seal?
Post by Gotanubike »
Oil seal
http://www.cmsnl.com/kawasaki-1999-h5-k ... 920491259/
Part number 92049-1259
Mechanical water seal(whatever that is, don't have one on my 1990)
http://www.cmsnl.com/kawasaki-1999-h5-k ... 490631002/
Part number 49063-1002
Use part number to search ebay and such or pop by local Kawi dealer and ask the to order you 1
1990 KDX200
superman27e
Re: Water pump seal?
Thanks, buddy!
Took a picture of my "oil."
Also, does anyone have any idea why oil keeps settling right here? Crank seal? I just cleaned it a week ago, and this always happens. If you'll notice, there area below that is fine, just that one area gets oil on it.
Gotanubike
Water pump seal?
Counter shaft sprocket seal. Just did mine a few weeks ago
May just be chain oil, though
1990 KDX200
Dekon
Water pump seal?
Post by Dekon »
It might be the counter shaft seal leaking. Also, I would get a case saver on it, one thrown chain and you might have a destroyed case.
Gotanubike
Water pump seal?
Counter shaft seal part #92050-033
Same one my '90 uses. I had a HARD time finding these so I ordered 2. Best price I could find was from a U.K. parts vendor www.oro2u.com
https://www.catalyst-findit.co.uk/index ... 58-613.KAW
1990 KDX200
superman27e
Thanks, guys! I'll get 'em ordered soon!
superman27e
I can't seem to find a case saver. Is this one of those hard to find KDX parts? Haha
s10gto
Water pump seal?
Post by s10gto »
superman27e
Water pump seal?
You guys are too awesome! Don't know what I'd do without this forum. :p
superman27e
Water pump seal?
Gotanubike wrote:Oil seal
Wouldn't I need the 92050 for the oil seal? Or is the counter shaft sproket seal and oil seal different? I've confused myself now. :p
http://www.bikebandit.com/oem-parts/199 ... 6#sch70374
Gotanubike
Water pump seal?
.....The countershaft seal(92050-033[reference #92050]) goes behind the front sprocket
The waterpump seal(92049-1259[reference #92049B]) that is causing your watery oil going behind the waterpump impeller.
1990 KDX200
superman27e
Yea, I just got confused on the part numbers. You gave me a link with the part number 92049 as the oil seal (counter shaft sprocket seal.) But I saw on bikebandit that their OEM part number is 92050. The 92050 is around $8 and the 92049 that you posted is only $1.xx. So, my question is, are they the same part?
Gotanubike
superman27e wrote:You gave me a link with the part number 92049 as the oil seal (counter shaft sprocket seal.)
Care to quote me there? 92049 is the reference number for the water pump seal from my first post
92050 is the reference number for the counter sprocket seal from my third post..
1990 KDX200
superman27e
Ohh, I see where I got confused. In your first post, you mentioned the oil seal (92049) and some how I thought I had already mentioned the counter shaft sprocket seal in my original post, so I thought that was what you were giving a part number for.
Sometimes, man....my brain....Haha
superman27e
So does the KDX 200 have a dang reserve coolant tank? I never knew that! Man, the guy who sold me this bike got me good.
s10gto
Water pump seal?
Post by s10gto »
They sure do. Nice to have if she gets a little warm in the woods.
Tedh98
Post by Tedh98 »
5+ years on the hybrid without a coolant tank and I have never had a problem. Most hybrid builds dont use the tank either.
I wouldnt spend a lot on putting one back unless it really bothers you.
Gotanubike
superman27e wrote:Ohh, I see where I got confused. In your first post, you mentioned the oil seal (92049) and some how I thought I had already mentioned the counter shaft sprocket seal in my original post, so I thought that was what you were giving a part number for.
Yeah I usually refer to it as the waterpump seal, but they never distinctively give all oil seals different names(water pump seal, clutch actuator shaft seal, shifter seal, counter shaft seeal, etc) They're all just called "Oil seal"
1990 KDX200
superman27e
Tedh98 wrote:5+ years on the hybrid without a coolant tank and I have never had a problem. Most hybrid builds dont use the tank either.
We'll see what happens. I'm gonna be replacing everything from bearings to plastics next month, so it's pretty much gonna be a brand new bike. Pretty excited about it!
