Hi dumb question but does any one know the length for a H rear axel spacers and which side is the shortest (right I presme)
Reason is, I'm building my hybrid (2001 KX125) and between getting the doner in parts, cleaning the KDX parts and other I have ended up with:
2 x 22mm
2 x 20mm
1 x 19mm
And haven't a clue as to which ones fit the KX.
I have measured the hub with and sistance between swing arm but don't know how much take up is required.
My theory is if I can take the KDX ones out of the mix it will narrow it down?
Thanks
Rear axel spacer question
- Tioli
- Country: Tasmania AUS
Re: Rear axel spacer question
I did not think the KX and KDX had the same diameter rear axle.
Obviously they do, or you would not be asking.
Sorry I can't answer your question.
'08 KTM200xc
KX100 for the boy
KX100 for the boy
Can't answer either. In messing around with fitting a reinforced (thicker around the axle) Devol rotor guard, I ended up doing a cut-and-try spacer fit when trying to put everything back together. Also had to shim the caliper holder to get everything to line up properly. Fortunately, I have a lathe so this work wasn't too difficult for me.
- Tioli
Thanks so far. They are all the same Ida. They look the same except for the slight diference in length.
If all else fails I can play with combinations and free spin the wheel to see if the chain has a bias to run to either side of the sprockets.
Can't say it's my preferred option hence the post.
I have a 2000 kx hybrid and both rear spacers are 20mm
- Tioli
Fantastic thank you.
I justl checked and the 2000 and 2001 have the same part numbers and I'm done
