220 piston
Posted: 06:49 pm Nov 06 2014
by jjavaman
Hi guys, I'm in the process of getting the RB carb/head done so it is time to see if it's a stock or aftermarket piston. I was told when I got bought the bike that it had been rebuilt so I was hoping it was a wiseco piston. Scraped the carbon off the crown and there was a b stamped into it. I look in the exhaust port and see those beautiful machined marks of a forged piston! I did a compression test before I pulled the head and it was 130lbs so I'm a happy camper!
Now my question, I can move the piston with my fingers. With the piston at tdc, I can turn it in the bore, just a bit, but still it moves around. Is that normal?
220 piston
Posted: 06:22 am Nov 07 2014
by Tedh98
jjavaman wrote: Now my question, I can move the piston with my fingers. With the piston at tdc, I can turn it in the bore, just a bit, but still it moves around. Is that normal?
You mean you can move it clockwise/counter-clockwise inside the cylinder? How much does it move?
Re: 220 piston
Posted: 06:13 pm Nov 07 2014
by jjavaman
That's right, it moves maybe a 1/16 " clockwise/counterclockwise.
Re: 220 piston
Posted: 06:27 pm Nov 07 2014
by ohgood
jjavaman wrote:That's right, it moves maybe a 1/16 " clockwise/counterclockwise.
hmmm I'm watching this one for accurate information
220 piston
Posted: 06:50 pm Nov 07 2014
by pumpguy
If it moves that much, I'd be real curious about the condition of the wrist pin bearing. Is there clunking or any up and down clearance at the piston when you rock the flywheel back and forth?
Re: 220 piston
Posted: 07:17 pm Nov 07 2014
by JasonK94Z
A new piston kit and wrist bearing is pretty cheap. Especially after you've already removed the head, etc. Replacing the piston is also an opportunity to clean the power valves.
220 piston
Posted: 07:22 pm Nov 07 2014
by Tedh98
jjavaman wrote: Scraped the carbon off the crown and there was a b stamped into it. I look in the exhaust port and see those beautiful machined marks of a forged piston!
Was there anything else stamped on the top of the piston? Wiseco's usually have several letters/numbers on the top.
Something doesn't seem right. Since you have the down time, I would pull the cylinder and inspect things further.
Re: 220 piston
Posted: 10:37 pm Nov 08 2014
by jjavaman
Ya,I'm going to pull the cylinder and clean the kips so I'll look a little closer at the piston then. Don't you love winter down time.
Re: 220 piston
Posted: 06:06 pm Nov 12 2014
by jjavaman
Hi can someone tell me if this is a forged piston? By looking at some previous posts I'm thinking it is because of the machining marks.
https://imageshack.us/my/images https://imageshack.us/i/eys6RaYJj
Re: 220 piston
Posted: 06:44 pm Nov 12 2014
by Tedh98
What is on the top of the piston? It should have Wiseco's P/N.
Re: 220 piston
Posted: 07:48 pm Nov 12 2014
by jjavaman
https://imageshack.com/i/exkFtWrVj All it has in the top of the piston is a B and a arrow. Hope this helps.
Re: 220 piston
Posted: 07:59 pm Nov 12 2014
by Tedh98
If that is all it has on the top then it isn't a Wiseco.
Re: 220 piston
Posted: 08:07 pm Nov 12 2014
by Tedh98
Now with the cylinder off, what is loose that causes the piston to rotate?
220 piston
Posted: 10:54 am Nov 13 2014
by IDRIDR
My 'assumed' stock 220 piston looked like that on top except it had a "C" instead of the "B."
I meant to find it last night and look at the side.
Re: 220 piston
Posted: 01:15 am Nov 14 2014
by jjavaman
Well I've decided that it's a stock piston,reading the manual it talks about the piston having a A or a B on the top and mine does. There is a lot of slop in the wrist pin,back and forth movement so I'm going to order me a wiseco.
Re: 220 piston
Posted: 08:37 am Nov 14 2014
by Julien D
You'll want a top end kit, or get the gasket set and wrist pin separately. Piston kit does not usually come with wrist pin bearing.
220 piston
Posted: 10:37 am Nov 14 2014
by pumpguy
If that excess clearance is due to an oversize bore in the connecting rod, a new wrist pin and roller bearing assembly won't solve the problem. I would suggest you remove the piston from the rod, and check the clearance with just the wrist pin and roller bearing assembly. If that bore is worn oversize, a new rod is probably the best solution.
