Shift shaft replacement
PWELLS
Post by PWELLS »
I have a 2005 kdx200 that needs the shaft replaced. What can I use to hold the flywheel while I remove the clutch basket? Thanks in advance.
Tedh98
Re: Shift shaft replacement
Post by Tedh98 »
This is how I usually do it, any type of aluminum, copper or soft metal between the gears. You can also lockup the rear tire with the bike in 5th or 6th gear.
kenpowell
Post by kenpowell »
I do it like Ted; I use a piece of 1/4" copper tubing with the end crushed to fit like Ted's picture.
Ken Powell
2012 KTM 300 XC with YZ SSS cartridges in the WP tubes
2003 YZ265WR with 2005 AOSS forks
2003 KX125 / KDX200 motor with YZ SSS forks
First Motorcycle - 1963 Harley 175 Scat
PWELLS
Post by PWELLS »
So gentlemen i did not need to remove the flywheel cover? Thank you. Now, what size is the nut for the clutch basket 22mm 23mm?
Tedh98
Post by Tedh98 »
Nope.
And I'm 99% sure it is a 22mm
I am not sure on a 1995 - 2006, but 1987 is 24mm.
PWELLS
Post by PWELLS »
All right,All right. Got some copper tubing. Going to get some new deep well sockets and spend the afternoon getting my sons bike fixed. Thank you Gentlemen.
