Does anyone know if a KLX 450 headlight/front fender can be made to fit an H series KDX?
Thanks,
Jeff
KLX 450 headlight/front fender on KDX???
- 6 Riders
Re: KLX 450 headlight/front fender on KDX???
Pretty sure the KLX head light uses rubber straps around the fork. If that is the case ( the 300 does use rubber straps) then it will fit. The front fenders between the KX, KLX and KDX use the same bolt pattern, or can be drilled to fit.
Thanks for the reply!
